I have a simple program, which receives data from UART interface and drives a WS2812b led strip. So, I'm using USART3 to receive data (in IRQ mode) and T3C2 (timer 3, channel 2) to drive LEDs. Here is the code:
https://hastebin.com/rucumovero.cpp
If I use the uart interface without enabling a timer, everything works just perfect, but when I enable the timer I start losing data. For example, here the log if I send 5 similar 32 byte packets [0x41..0x60]
read 29 byte(s): 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F
read 29 byte(s): 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 60
read 28 byte(s): 41 42 43 44 45 46 47 48 49 4A 4D 4E 4F 50 51 52 53 54 55 56 57 58 59 5A 5D 5E 5F 60
read 29 byte(s): 41 42 43 44 45 46 47 48 4B 4C 4D 4E 4F 50 51 52 53 54 55 56 57 58 5A 5B 5C 5D 5E 5F 60
every time 3~4 bytes are lost.
I tried to use different baud rate, different usart port - the result is the same. The timer interval is set in line 142:
timer_set_period(TIM3, WSP);
where
#define TICK_NS (1000/72)
#define WSP (1300 / TICK_NS)
If I comment out this line, the problem will disappear, but, of course, I won't be able to drive LEDs without it.
So, it looks like I can't drive WS2812b leds and receive data from UART at the same time. Is it supposed to behave like this? Any idea how can I fix it?
