6
When I was younger I played with micro controllers and moved on over to programming. I decided to play around with circuits again, and a few things are not clicking.
Specifically, I am not quite sure how exactly transistors effect circuits in regards to voltage and current. When I try to figure it out, I think of it through the lens of how a resistor effects the nature of the circuit, is this a faulty perspective?
For example, when I use a NPN transistor as a switch for another circuit with a LED. The base of this transistor is switched from a separate power source than that of the LED. The LED is from a 9V source, and the transistors base is from a 1V power source. The transistor has a 1k Ohm resistor, however it appears I do not need any resistance for the LED, despite it coming from a 9V source? The LED has a max voltage of 2V and a max current of 20mA.
I am unsure how the LED is not blowing, and I am also unsure how the current is only 18.6 mA.
Here is a schematic of the scenario in which I am describing: Circuit Perhaps I have missed something basic,, which makes this hard to understand. If that is the case I would appreciate being pointed in the right direction. Since I am relatively new, it is hard to think of what search terms to use in order to get accurate results.
Thank you.
Edit: Wow, all very good answers. I wish I could mark them all correct. I'll mark the simplest answer because it helped with the initial grasp, but to anyone stumbling upon this question, the other answers help give you a deeper direction.
  • \$\begingroup\$ You need to read about loadlines. \$\endgroup\$ Dec 29, 2017 at 3:24
  • \$\begingroup\$ Fortunately for you 9 volt batteries have a limited current they can supply, or your LED and transistor would have been destroyed. \$\endgroup\$
    – user105652
    Dec 29, 2017 at 5:15
  • \$\begingroup\$ Also keep in mind that there are many different types of transistors. You are modelling with a BJT ("bipolar junction transistor"), which makes a good amplifier or regulator, but only a mediocre switch. If you want to switch power, look up a MOSFET ("metal-oxide semiconductor field effect transistor"). It behaves closer to what you may expect. Why are BJTs often used as switches? They were discovered earlier, and so people used what they had. And BJTs cost less than MOSFETs, although not so much recently. \$\endgroup\$
    – bitsmack
    Dec 29, 2017 at 8:12
5 Answers 5
11
You have to remember that a transistor is a kind of "current valve". It allows an amount of current to pass between collector and emitter that is \$H_{fe}\$ times larger than the current that passes through the base of the transistor.
In your example \$H_{fe}\$ is apparently set to \$100\$. The base current is only \$186\mu{A}\$ so the collector current can not exceed \$18.6\mu{A}\$. (It could of course be less than that if the current is not available, at which point the transistor is saturated.)
As you expect the LED drops about \$2V\$ across it. The remaining \$7V\$ from the \$9V\$ supply is dropped across \$V_{ce}\$.
So in this instance the transistor is not acting as a switch, but as a linear current regulator.
However, not a very good one since the \$H_{fe}\$ of transistors is actually a very vague value. If you wanted a current limiter, the circuit below is better and relies on a resistor value to set the current.
$$ I = 0.7/R1 $$
  • \$\begingroup\$ Okay, this makes more sense to me now -- I think ;). In regards to using it as a "switch", what do you think I am doing wrong? I thought that supplying the base with power is what allows the flow of the LED circuit? Though, I now see when I flip the switch on the transistors side, the current does still flow for the LED, but only at 3.58 nA. \$\endgroup\$
    – Toskr
    Dec 28, 2017 at 19:48
  • \$\begingroup\$ @Toskr you actually lucked in with the currents if you wanted 20mA LED current. If you need it fully on you would need a much smaller base resistor. But then you would need a resistor in series with the LED. \$\endgroup\$
    – Trevor_G
    Dec 28, 2017 at 19:51
    \$\begingroup\$ "[the current] could be less than that if the current is not available, at which point the transistor is saturated." -- I always found this terminology confusing: whether the transistor is saturated or not doesn't really have anything to do with the transistor per se, but with the circuit around it, since that's where the limitation for the current comes from. \$\endgroup\$
    – ilkkachu
    Dec 28, 2017 at 20:37
  • \$\begingroup\$ @ilkkachu yes I know what you mean. It is hard to explain without putting the cart before the horse. \$\endgroup\$
    – Trevor_G
    Dec 28, 2017 at 20:44
10
The trick here is to realize that transistors (essentially) work in one of two modes: linear and saturated. When used as switches, as is usually the case, they have a very low collector-emitter voltage and a high base current - or, to put it another way, they work with low gain. Under these conditions, collector current can vary quite a bit with not much change in Vce. In turn, this means that collector current needs to be controlled, and in LED circuits this is normally done by adding a series resistor to limit current.
However, there is another mode, called linear mode, which is characterized by Vce greater than the base-emitter voltage and higher gains, typically in excess of 100. When operating at these levels, collector current is set by the product of base current and gain, and variations in Vce will have little effect on collector current. In other words, the transistor will act as a current amplifier.
In the circuit you've shown, 186 uA is small enough that, at a gain of 100 and taking into account the voltage drop of the LED, the transistor is operating with 7 volts Vce, which means that it is in linear mode. It is effectively providing the voltage drop which would "normally" be done by a resistor in series with the LED.
This has plusses and minusses. On the one hand, it makes for a simple circuit. There is no need for an extra resistor. The down side is that the transistor dissipates more power than would otherwise be the case. This is not actually a problem in this particular instance, since the total power is only 130 mW, and almost any transistor can handle it. If the transistor were driven into saturation Vce would be on the order of 0.2 volts, and the transistor (at the same current level) would only dissipate about 4 mW, with a resistor to drop the other 126 mW. In general, it's cheaper to dissipate power with resistors rather than transistors.
Why not do it "normally" as you've done it? Because transistors show wide (3:1 or better) variations in gain. So if you drive a bunch of LEDs with your circuit, they will almost certainly show wide variations in brightness. Plus, of course, wide variations in power dissipation.
Don't let models fool you. Your simulation uses a nominal gain value of 100, and this is a perfectly good starting assumption when modelling a circuit. But it's not something you can count on in the real world. You need to read data sheets, and keep a close eye on the difference between "typical" figures and max/min.
EDIT - And note that I said "essentially". Yes, there is an intermediate condition. For a given collector current and varying base currents, as Vce gets low (down around 1 volt) there is a transition region where the gain starts dropping. But gain varies anyway, both with current and voltage.
    \$\begingroup\$ +1 I never know why they always go for 100... finding small signal transistors with typical Hfe anywhere close to 100 is rare. \$\endgroup\$
    – Trevor_G
    Dec 28, 2017 at 19:53
  • \$\begingroup\$ As well as being a reasonable value, and pessimistic for most small signal transistors, it's easy to do sums with, base current = 1% of collector current. \$\endgroup\$
    – Neil_UK
    Dec 28, 2017 at 20:00
6
The Transistor you have shown has a current gain of 100. So since your base current is limited, the collector current is limited by the linear current gain of 100,
However, we generally use transistors as switches for LEDs where the current gain drops towards 10 at the rated Vce(sat). ( usually hFE starts reducing below Vce=2). So the better design saturates the base emitter diode with 10% to 5% of the load current ( i.e. 2 to 1mA) and then use a collector series Rc to provide the voltage drop and limit the current.
With these assumptions of Ic=20mA, Vf=2V, V+=9V then Vce=0.5V @ Ib=5%Ic or Ic/Ib=20 thus V(Rc)=(9-2-0.5)[V] /20 [mA]= 325 Ohms
If one wanted more LEDs from 9V bat, you might be able to support 4 in series with some wider variation in brightness as battery drops to 8.5V or 3 in series for less variation and compute a lower Rc value. (9-3*2.0V-0.5V)/20mA = 125 Ohms
Here is graphical method to predict the behavior of the transistor plus resistor plus LED
"Specifically, I am not quite sure how exactly transistors effect circuits in regards to voltage and current. When I try to figure it out, I think of it through the lens of how a resistor effects the nature of the circuit, is this a faulty perspective?"
Yes I can see the confusion here. Maybe If I explained the transistors function seen from "electron flow theory" as well as "conventional (aka hole flow thoery)"
Conventional theory:
A Transresistor's (now called transistor) function is to vary the voltage drop across the collector and emitter with a small voltage applied to the base.
Electron Flow theory:
A transistor's function is to vary a larger current across the collector to emitter junction with a smaller current across the base to emitter junctions.
Hopefully that clears the confusion.
