I have a 12V led strip connected to a (cheap) 12V 5A switching mode supply.
The supply is connected to a remote control switch.
The supply does not have earth connection (only neutral and live)
The supply have an European plug ( Live and neutral can be switched by turning the plug 180°)
Since the remote control switch only cuts one connection (I think) if I connect the plug in a certain way the live or the neutral wire still reaches the power supply even if the "return path" is blocked.
In one of the 2 cases I noticed that if I touch the led strip some of the leds near the point that I touch turn on very dimly. I have no body->earth connection except for the body capacitance.
The questions:
- Is this caused by me working as an antenna or by me working as a capacitor for some low current AC signal on the output of the power supply?
- Is this safe?
- Is the power supply working properly?
- Is the remote control switch working properly?
