I have a Tektronix TDS 2024B Oscilloscope. For some reason it displays the derivative of the signal. It cannot be the "Math" feature as it only computes addition or subtraction of 2 signals supplied through CH1 and CH2. I even tried to restore the factory settings but it didn't solve the issue either.
Do you have any suggestions on how to make it display the signal itself instead of the derivative?
The signal I am supplying: (A square wave with 25% duty cycle.)
As suggested by Spehro Pefhany I connected the probe to probe comp and this is what I got:
Then I did the same with a different probe, and this is what I got:
I guess this result validates your hypothesis that the initial probe/cable is broken.
Andre, this is a picture of the initial probe I was using. I am not sure if it has any shielding at all as it is thinner than a regular coaxial cable. Let me know what you think.
