I am interfacing a 3.3V FPGA to a 5V DSP. I am using this bidirectional voltage transceiver: http://www.nxp.com/documents/data_sheet/GTL2000.pdf
In the diagram in page 4 they're using pull up resistors at the high voltage side and they state:
The processor output can be totem pole or open drain (pull up resistors may be required) and the chipset output can be totem pole or open drain (pull up resistors are required to pull the Dn outputs to VCC).
The DSP I'm using is TI TMS320C31 and will be interfaced to the FPGA Cyclone EP1C6Q240C8N.
Should I use pull up resistors on one of the sides or both or I don't even need them?
