The above picture is an I-type format register. I am confused as to why the largest constant possible is $$2^{15}$$ Should the largest possible constant be $$2^{16} -1$$
1\$\begingroup\$ Please can you edit your question and greatly improve it by details such as the CPU you're using and why. The better the quality of your question, the better the quality of the answers you will attract. \$\endgroup\$– TonyMMar 5, 2018 at 22:39
\$\begingroup\$ Just guessing: This might be a MIPS instruction. In that case, it's 2¹⁵-1 because the value is sign-extended, not zero-extended. (It is treated as a signed 16-bit integer) \$\endgroup\$– Jonathan S.Mar 5, 2018 at 22:47
\$\begingroup\$ Yes, its a MIPS instruction \$\endgroup\$– user3067059Mar 5, 2018 at 23:20
Add a comment
1 Answer
In the MIPS architecture, the immediate field of I-type instructions is a signed 16-bit value in two's complement. One of those 16 bits is the sign bit, the other 15 remain for the magnitude.
Therefore, the range is -2^15 (-32768) to 2^15-1 (32767); that's still 2^16 different values in total.
\$\begingroup\$ why is the max positive 1 less than max negative? \$\endgroup\$ Mar 5, 2018 at 23:34
\$\begingroup\$ @user3067059 That's because of two's complement. Instead of having both a positive and a negative zero (which would be a waste and complicate computations), there's only one zero. That frees up a bit pattern for an additional number, in this case another negative one. There are other representations of signed numbers that handle this differently, but MIPS chose two's complement. \$\endgroup\$ Mar 5, 2018 at 23:40
\$\begingroup\$ Zero does not have a -ve sign so they are equal. \$\endgroup\$ Mar 5, 2018 at 23:42
