I am new to MPLAB XC16 IDE. I am generating a simple blinking LED code to understand the basics of the microcontroller PIC24FJ32GA002.
The main file is as follows:
#include <xc.h>
#include <libpic30.h>
#define sysclock 96000000UL
#define FCY sysclock/4
// CONFIG2
#pragma config POSCMOD = XT // Primary Oscillator Select (XT Oscillator mode selected)
#pragma config I2C1SEL = PRI // I2C1 Pin Location Select (Use default SCL1/SDA1 pins)
#pragma config IOL1WAY = ON // IOLOCK Protection (Once IOLOCK is set, cannot be changed)
#pragma config OSCIOFNC = OFF // Primary Oscillator Output Function (OSC2/CLKO/RC15 functions as CLKO (FOSC/2))
#pragma config FCKSM = CSDCMD // Clock Switching and Monitor (Clock switching and Fail-Safe Clock Monitor are disabled)
#pragma config FNOSC = FRCDIV // Oscillator Select (Fast RC Oscillator with Postscaler (FRCDIV))
#pragma config SOSCSEL = SOSC // Sec Oscillator Select (Default Secondary Oscillator (SOSC))
#pragma config WUTSEL = LEG // Wake-up timer Select (Legacy Wake-up Timer)
#pragma config IESO = ON // Internal External Switch Over Mode (IESO mode (Two-Speed Start-up) enabled)
// CONFIG1
#pragma config WDTPS = PS32768 // Watchdog Timer Postscaler (1:32,768)
#pragma config FWPSA = PR128 // WDT Prescaler (Prescaler ratio of 1:128)
#pragma config WINDIS = ON // Watchdog Timer Window (Standard Watchdog Timer enabled,(Windowed-mode is disabled))
#pragma config FWDTEN = OFF // Watchdog Timer Enable (Watchdog Timer is disabled)
#pragma config ICS = PGx1 // Comm Channel Select (Emulator EMUC1/EMUD1 pins are shared with PGC1/PGD1)
#pragma config GWRP = OFF // General Code Segment Write Protect (Writes to program memory are allowed)
#pragma config GCP = OFF // General Code Segment Code Protect (Code protection is disabled)
#pragma config JTAGEN = OFF // JTAG Port Enable (JTAG port is disabled)
int main(void) {
TRISB = 0xFFFF;
while(1) {
PORTB = 0xFFFF;
__delay_ms(1000);
PORTB = 0x0000;
__delay_ms(1000);
return 0;
The project builds successfully with this build output:
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'C:/Users/mohsi/MPLABXProjects/PIC24FJ32GA002.X'
make -f nbproject/Makefile-default.mk dist/default/production/PIC24FJ32GA002.X.a
make[2]: Entering directory 'C:/Users/mohsi/MPLABXProjects/PIC24FJ32GA002.X'
"C:\Program Files (x86)\Microchip\xc16\v1.33\bin\xc16-gcc.exe" main.c -o build/default/production/main.o -c -mcpu=24FJ32GA002 -MMD -MF "build/default/production/main.o.d" -g -omf=coff -DXPRJ_default=default -legacy-libc -O0 -msmart-io=1 -Wall -msfr-warn=off
"C:\Program Files (x86)\Microchip\xc16\v1.33\bin\xc16-gcc.exe" system.c -o build/default/production/system.o -c -mcpu=24FJ32GA002 -MMD -MF "build/default/production/system.o.d" -g -omf=coff -DXPRJ_default=default -legacy-libc -O0 -msmart-io=1 -Wall -msfr-warn=off
"C:\Program Files (x86)\Microchip\xc16\v1.33\bin\xc16-ar.exe" -omf=coff -r dist/default/production/PIC24FJ32GA002.X.a build/default/production/main.o build/default/production/system.o
make[2]: Leaving directory 'C:/Users/mohsi/MPLABXProjects/PIC24FJ32GA002.X'
make[1]: Leaving directory 'C:/Users/mohsi/MPLABXProjects/PIC24FJ32GA002.X'
BUILD SUCCESSFUL (total time: 6s)
Yet still the project only compiles .a file in the project folder/dis/default/production folder:
Here are the project properties to show that I am using the correct micro controller using Simulator in MPLAB X IDE using XC16 compiler:
Any help would be appreciated. For context, I need to simulate this microcontroller in Proteus simulator. So need the .HEX file from the project.
