I have 2-switch forward converter operating at 83khz frequency. Load current must be 10A maximum D=0.5 I2=Iload*sqrt(D) I2=7.1A transformer turns ratio is 2:1, so I1=3.55A
The voltage applied to primary is 300V (220*sqrt2)results in value ner 300V. I have ETD59 core. lets calculate E per turn: Assume that flux swing is 0.2T (Br is 0.066T, Bmax is 0.266T, so dB is 0.266T) Lets calculate E per turn: E(1 turn)=dФ/dt=deltaB*S(core)*f/D
D max for forward converter is 0.5. OK
So, E per turn looks like 12.21 V. Ok.
Lets calculate primary turns: 300/12.21=24.57 turns of primary (assume Np=26 turns). OK
The transformer must be 2:1, So there must be 13 turns of secondary (Ns=13)
The next part is the part that i dont understand: magnetizing current depends on value of magnetizing inductance, right? And magnetizing inductanse is Al*Np^2 (Al for ETD59 core is 5300+-20%). OK.
If i assume that we have the worst case, Al(worst)=4240nH/turn So, calculating magnetizing inductance gives me Lm=Al(worst)*Np^2=2.86mH Is this value ok? I have also found a formula for calculating minimum value of magnetizing (primary) inductance:
Here, Drmin is minimum Duty ratio, Vsmax - maximum supply voltage, fs is a freqeuncy and delta ilmag is a swing of current flowing through magnetizing inductance. Is value of magnetizing inductance so necessary? If i have a transformer which has 26 turns of primary and 13 turns of secondary, is magnetizing current a concern? Is it a good idea to increase the number of turns to get higher value of inductance? This should reduce magnetizing current... Where am i wrong? If i assume that Drmin is 0.15 (i just assume - i am not sure), Vsmax=400V, f-83kHz and delta i(lmag)=0.355A (its 10 percent of rms primary current), it gives me Lmag=2mH So, is it ok? If i would done calculation i described before for a transformer which operated at 100kHz of frequency, I get 16 turns of primary and 8 turns of secondary... So, if i calculate value of magnetizing current the same way (it is MINIMUM inductance required?) i get inductance value L(100kHz)=Al(worst)*16*16=1mH So, it looks like according to formula for Lmagmin, this value isn enoght to provide 0.355ma of magnetizing current Im totally stuck. And does the value of magnetizing current affects core saturation? If it is MINIMUM required value of inductance, more is better?
