Could it be possible to use a USB-C Cable to USB-C Cable with both end controlled by me, just for use as simple copper wires, without negotiation, etc... Because i would not be using the USB protocol.
I ask this question because i saw that a lot of usb-c cables have a chip inside them for negotiating, and a e-marker. And also, are the ground cables connected together, and the vcc ones ? Because that would be problematic if we want to connect them independently
So do you think it would be possible with any usb-c cable, so including ones with a chip inside it ?
