In case of parallel connection, is the statement "Depending on the current(electric current) value, logic (0 or 1) is determined." True or False? I do not understand why current cannot affect the voltage value in this case. Don't we need another assumption about the resistors having the same value in order for the statement to be false? I am confused.
This is a TF question from my logic design class. The answer provided is false because it is determined by voltage. I marked this as true because I thought current can affect the voltage therefore determine the logic value. But when I mailed my professor he said this is not true in case parallel connection. I am wondering why this is the case.
current value
? .... does it meanthe most recent value
, or does it meanthe value of electric current
? .... please clarify the question .... do not add additional info into comments \$\endgroup\$
