If all you want is to simulate, then a behavioural approach might be more handy than using real curcuit elements, such as a MOS (which, as I see, and as the other answers say, you have trouble setting it right). Instead, you can use the voltage controlled switch.
The control voltage you're using for that MOS is using a zero rise/fall time, which can't be physically true (no instant rise/fall in nature), so LTspice sets it, by default, to 10% of the Ton
. In this case, for Ton=5\$\mu\$s, Trise=Tfall=1\$\mu\$s, which not only gives you an awful transition time, but also extends the value of Ton, from 50% Trise to 50% Tfall, to Ton+(Trise+Tfall)/2=6\$\mu\$s.
Your other values, for LC filter, for example, are awfully chosen: 1H and 10nF? How did you calculate those? I'll skip the load, maybe you intended to see the open load output? Somehow I doubt it.
If you're using the default diode, it would help setting its parameters epsilon
and revelsilon
, which control the knee-region to be a simple quadratic approximation, thus avoiding the sharp transitions that can cause the solver to yield timestep too small
errors due to the possible discontinuity that results in a sharp derivative around that point. Or, you can keep things simple and use the default, quasi-real model by simply setting .model d d Cjo=1p
, which only adds a capacitance to the junction in order to improve comvergence, while discarding the ideal model.
Also, using startup
and uic
, both, is not redundant, but not recommended, either (unless there are strict specifications, are there?). In your case, you're starting a switching application, so neither are needed.
Here's a reworked version of what you need, with some recalculated values for a 6.5V@1A output:
I fully agree with @Dave Tweed, too often people rush to blame the tool rather than the user.
Here's what a quasi-real setup would be:
Note the PMOS (usually when in high side), driven by a signal that's between GND
and 13V
(or close, some losses simulated) -- as the other answers have suggested --, and some parasitics. Instead of V2
there's usually some sort of control, voltage- or current-mode, that's a different question, but one that you should be able to find already answered.
