I am trying to figure out if the equivalent resistance (or similarly conductance) of a resistor network can be calculated using Qucs (as opposed to solving the Kirchhoff equations directly, or doing the numerical Star-Mesh transform on the network).
For instance if we know the graph/network characteristics, that is, the vertex set (i.e. how many nodes), the edge (bond) set and the resistance values corresponding to each bond (so between a chosen pair of vertices),
- How can we input the resistor network as such into Qucs? (can netlists be used for this purpose?)
- Assuming the above point is possible, can we then use Qucs to estimate the equivalent resistance of the network? That is, can we set up a Qucs simulation for this type of calculation? (e.g., using a fixed voltage generator in an AC simulation?)
Being a complete novice to Qucs, any hints at any level, be they basic or advanced, would be extremely valuable to me. Unfortunately, in the existing Qucs tutorials I haven't found any examples pertaining to the above type of calculations.
In case you prefer to answer with a working (dummy) example, here's a network we can work with:
Example network for testing purposes: 4 nodes only, labelled from one to four. The only bonds in the network are: {1,2} with resistance 5 ohms, bond {1,3} with resistance 10 ohms and bond {2,4} with resistance 5 ohms. And we're trying to find out the resistance between the input and output.
