I have an emergency light device which is given by a small manual back side of it with some electrical specification. They are:
Voltage: AC90-240V 50-60Hz
Current: 0.1A
Power: 18W
Can I calculate the actual voltage rating of this device?
The device has a rechargeable battery inside it and there is no other informations available in its manual.
When I used the formula:
$$P = V \cdot I$$ $$V=\frac{P}{I}=\frac{18}{0.1}=180~V$$
Is it correct that the device's output is 180V? (I think it is very high and my calculating approach is failed).
