I want to create an Inductance meter with an arduino nano, for that I follow that link whose theory convinced me : tutorial
(The Diode on schematic remove analog negative voltage, Edit: I have wrong, excuse me surely for prevent inductor negative voltage because out signal not contain diode or maybe in the comparator ?) and then the comparator convert it into square wave based on ON/OFF DC ? Getting wavelenght or pulse in time and then calculating resonant frequency and finally the inductor value based on known capacitors values.
This tutorial use an LM339N comparator, but I learn an I read : op-amp can be used as comparator.
I have not a comparator but I have an TLV2462 op-amp ,can I use this TLV2462 - Op Amp - Dual Rail-to-Rail as comparator in place of LM329N comparator ?
My goal is to create an Inductance meter for 'nH' unit... I learn, I read but i'm confuse. Also, I know the discharge inductor can create a big negative voltage spike. I would not want to burn my arduino (perhaps the diode is here for that), that's why I'm always on the theoretical part.
Thank's for your help.
