I am designing a circuit in which has a voltage supervisor (MCP121-33)with active low output nRST connected to RESET input of the microcontroller which is straightforward. Also, there is a another requirement in which the RESET input of the microcontroller has to be driven by one of the GPIOs of MCP2221 (USB to I2C/UART).
The GPIOs of MCP2221 are all push pull and not open drain.
How to connect MCP2221 GPIO and nRST from the regulator such that we can RESET the microcontroller using either of the sources.?
Any buffers with open drain is required on the push pull GPIO? please clarify.
Thanks in advance....
Datasheets: MCP2221 (USB to I2C/UART) AND Voltage monitor
