I'm kinda new to electronics and programming, but I managed to make a DS1307 RTC functional when it is used by only one program (I'm using C code). Buf if I try to use it in multiple programs at the same time, it occasionally gives me some strange dates and times.
For example, I'm using these two programs:
  • test.c
 #include <stdio.h>
 #include <stdlib.h>
 #include <time.h>
 #include "ABE_ExpanderPi.h"
 void main() {
    int i = 0;
    while( i < 100 ) {
            struct tm datetime;
            char buffer[80];
            datetime = rtc_read_date();
            if (strftime(buffer, sizeof buffer, "%Y/%m/%d;%H:%M:%S", &datetime)) {
            else {
                    puts("strftime failed");
                    exit(1);
            printf("%s\n", buffer);
            i++;
            usleep(10000);
  • test2.c
 #include <stdio.h>
 #include <stdlib.h>
 #include <time.h>
 void main() {
    int i = 0;
    while( i < 100 ) {
            struct tm datetime;
            char buffer[80];
            else {
                    exit(1);
            i++;
            usleep(10000);
The DS1307 functions can be found in ABElectronics_C_Libraries.
When I run both at the same time, it shows me something like this:
 2018/07/11;19:07:53
 2018/80/40;05:06:92
 2018/80/40;05:06:92
 2018/07/11;19:07:53
 2018/80/40;05:06:92
 2018/07/11;19:07:53
 2018/80/40;05:06:92
 2018/07/11;19:07:53
 2018/80/40;05:06:92
 2018/07/11;19:07:53
 2018/07/11;19:07:53
 2018/07/11;19:07:53
 2018/07/11;19:07:53
 2018/07/11;19:07:53
 2018/07/11;19:07:53
 2018/80/40;05:06:92
 2041/53/02;90:12:90
 2018/07/11;19:07:53
 2018/80/40;05:06:92
 2018/07/11;19:07:53
 2018/80/40;05:06:92
 2018/07/11;19:07:53
 2018/07/11;19:07:53
In my project I will be using the RTC more than twice at the same time. Can you help me, please?
    \$\begingroup\$ I imagine the correct way to do this is to have a single program that gets the time from the RTC, and then whenever another program needs the time, it calls that dedicated program, and ensures that theres only ever one instance of the RTC program running. \$\endgroup\$
    – BeB00
    Jul 11, 2018 at 18:22
  • \$\begingroup\$ Linux actually has a driver for the DS1307 built-in, so it would probably be best to just use that. \$\endgroup\$ Jul 11, 2018 at 19:31
  • \$\begingroup\$ Why read the time/date from the RTC when you can read it from the system. When you have an RTC the Linux driver will read it and set the system time/date. Any program (and multiples) can read from the OS without interference. \$\endgroup\$ Jul 11, 2018 at 22:09
The problem you are having is one of concurrent access. Both processes are reading from the same file and so depending on the OS, one process gets a few bytes, then the other one, then the other one, etc. The mistakes will be seemingly random and based off how the OS schedules tasks to run. So the nice tidy sequences of date-time information from the DS1307 is getting chopped up and divided between the two processes, resulting in nonsense for both.
I would recommend looking into a shared memory solution. You would have a single process that is allowed to call rtc_read_date that places "messages" in a FIFO structure in shared memory. Then all the other processes that need date-time information could take the "messages" from the FIFO structure. This is not exactly trivial for a beginner but would be great to learn. Looking through this repository would be a good start.
