I have rewound a microwave oven transformer to produce a low voltage on the secondary. I'm not sure what the ampere rating of the transformer is but its about 4mm thick wire on the primary. I wound the transformer to be 93:3 turns, yielding about 3 volts on the secondary. If the input max is 20A, that gives me around 600A on the secondary. Still about 2200W. Trouble is, the secondary appears to have very little current running through it. Why is this?
Only reason I can think of is the inductance of the primary being high enough to limit the current to less than 20A or something. 93 turns, 80 mm loop diameter, 4mm wire diameter, and relative permeability of 4000 (transformer steel) yields 5.35 H, which is huge. I'll bet if I plugged that into the impedance formula of 2 x pi x f x H (60Hz) it would be a huge resistance. Yeah, its 2kOhm, which makes the current max on the primary 54 mA @ 110V I'm guessing? One thing I may have confused is the reactance for a air core coil vs an iron core coil.
Anyways question is, what's wrong with my transformer? Why isn't the secondary high current? What can I do to get high current? I realize I'm probably using the wrong wire size for 600A, yes.
