We are going to use GAP PAD HC 5.0 thermal pad to transfer the heat from a FPGA (XCKU040) to a heatsink. My question is regarding the thickness I should choose to obtain best performance.
On the one side, I understand that lower thickness = lower thermal resistance = higher heat transfer. On the other side, higher thickness allows it to absorb more deformations in the chip / heatsink surface, but it is worse in terms of heat transfer.
Is this correct? Any more ideas?
Thank you very much.
