I am in the process of designing a fancy USB type c cable (paracord, colourful heat-shrink, coils etc) And I'm worried about resistor values, I don't want to blow my phones port or the charger.
I would like to create a usb 2.0 cable and I think to allow it to be used for fast charging + data I will have to add a 56k pulldown resistor on the D+ and D- lines. is this correct? Does this resistor get added on both sides of the cable, totalling 4 resistors in the cable? Can someone help me with a schematic?
These are the connectors I will be using, one on each end of the cable
With these will I have to remove the resistor from one side?
