9
I'm a beginner studying The Art of Electronics, and on page 25 they introduce the differentiator. Basic circuit like so:
RC Diff Circuit
They give the complete equation:
$$ I = C \frac{d}{dt}(V_{in} - V) = {V\over R} $$
I understand this so far. But then they say: if we choose R and C small enough so that \$\frac{dV}{dt} \ll \frac{dV_{in}}{dt}\$, then...
$$ C\frac{dV_{in}}{dt} \approx \frac{V}{R} $$
This I don't follow. Can someone elaborate or explain a bit more? I see why the above equation makes it a differentiator -- V is proportional to \$\frac{dV_{in}}{dt}\$. But why does a small R and C cause the one derivative to me much less than the other?
11
If you rearrange the first equation, you get
\$C\dfrac{dV_{in}}{dt} = \dfrac{V}{R} + C\dfrac{dV}{dt}\$
So if you reduce C enough, you'll make the derivative term on the right insignificant compared to V/R, and you'll get your second equation.
Alternately, if you reduce R, you'll make the V/R term larger, and again the right-hand-side derivative term will become insignificant, and you'll get the desired result.
So I'd say it's not that you must decrease R and C together, but you do have do some combination of reducing R and reducing C to make the circuit work like a differentiator.
  • 4
    \$\begingroup\$ It becomes even more clear if you divide through by C, which puts the R*C product in a term by itself. It's that product that needs to be small, which makes the V/RC term large. \$\endgroup\$
    – Dave Tweed
    Commented Sep 2, 2012 at 18:41
  • 5
    \$\begingroup\$ I find that H&H tend to skip a few too many steps in their explanations, making their line of thinking hard to follow at times, even for experienced engineers. The non-mathematical (hand-waving) description of this example is that the R-C time constant needs to be small -- the cutoff frequency 1/RC needs to be large with respect to the signal frequencies -- so that nearly all of the input voltage appears across the C, and the voltage across the R is almost entirely due to the current, which is the derivative of the input voltage. \$\endgroup\$
    – Dave Tweed
    Commented Sep 2, 2012 at 19:25
    \$\begingroup\$ @DaveTweed "I find that H&H tend to skip a few too many steps in their explanations, making their line of thinking hard to follow at times" I couldn't stop writing to you how much I agree with your comment. It is a great book but I dont know why they skip many derivations which makes things painful.. \$\endgroup\$
    – user16307
    Commented Jun 13, 2016 at 0:20
Another way to look at this is in the frequency domain rather than the time domain.
What you have is a passive 1st order RC high pass filter. The transfer function is:
\$\dfrac{V_{out}}{V_{in}} = \dfrac{j\omega RC}{1 + j \omega RC}\$
When \$ \omega << \frac{1}{RC}\$
\$\dfrac{V_{out}}{V_{in}} \approx j \omega RC\$
But this is just the transfer function of an ideal differentiator.
The requirement given in the text is essentially the same requirement as above. The basic idea is that this high-pass filter "looks like" a differentiator well below the corner frequency.
Assuming RC is small, we want to solve:
$$RC\frac{dV_{in}}{dt}=V+RC\frac{dV}{dt}.$$
I was a bit unsatisfied as to why we would neglect the term RCV'(t) on the right, but not RCVin'(t) on the left. So instead let's find a solution using power series.
We will abbreviate the derivative as D, so:
$$DV_{in}=\frac{dV_{in}}{dt};\;DV=\frac{dV}{dt}.$$
Let's also abbreviate
$$\epsilon=RC.$$
The equation is then
$$\epsilon DV_{in}=V+\epsilon DV,$$ $$(1+\epsilon D)V=\epsilon DV_{in}.$$
Now, we 'divide both sides by (1+ϵD)', which can be made rigorous using power series. This gives the solution
$$V=\frac{1}{1+\epsilon D}\epsilon DV_{in}.$$
Assuming ϵ=RC is small, we can use the power series expansion
$$\frac{1}{1+x}\approx 1-x,$$
which is valid whenever x is small. This gives
$$V\approx \epsilon DV_{in}-\epsilon^2D^2V_{in}=RC\frac{dV_{in}}{dt}-(RC)^2\frac{d^2V_{in}}{dt^2}.$$
For small RC we can neglect the second term.
To be precise, we need (RC)D to be small. Note that this is unitless, since RC has units of time, and the derivative D has units inverse time. In other words, the time constant RC has to be small compared to the rate at which our signal Vin changes.
  • \$\begingroup\$ hi, $$(1+ϵD)V=ϵDV_{in} $$ is wrong. Because in $$ ϵDV_{in}=V+ϵDV $$ Last item ϵDV is not eaqul to ϵ * D * V, please see We will abbreviate the derivative as D, $$ DV = \frac{dV}{dt} $$ \$\endgroup\$
    – Tom
    Commented Aug 18 at 0:15
  • \$\begingroup\$ Sorry I don't know what you are saying? \$\endgroup\$ Commented Aug 19 at 2:43
  • \$\begingroup\$ D is a linear operator which takes a function f to its derivative f'. See arxiv.org/abs/1802.09343 or ruvi.blog/posts/electronics/rcoperatormethod \$\endgroup\$ Commented Aug 19 at 2:47
  • \$\begingroup\$ Sorry for my bad English. I know "D is a linear operator which takes a function f to its derivative f'.". I say in your answer, you write $$\epsilon DV_{in}=V+\epsilon DV$$ then, you get $$(1+\epsilon D)V=\epsilon DV_{in}$$ I think $$(1+\epsilon D)V=\epsilon DV_{in}$$ is wrong. Because $$V+\epsilon DV$$ is not equal to $$(1+\epsilon D)V$$ Because DV is a whole, as you said: $$DV=\frac{dV}{dt}$$ You do is like: $$x + 32x = x *(1 + 32)$$ for $$V+\epsilon DV$$ Can you understand what I’m saying now? \$\endgroup\$
    – Tom
    Commented Aug 19 at 7:54
  • \$\begingroup\$ Your English is great, now I understand what you are saying. But what I'm saying is that $DV$ does not have to be a whole. Imagine $A$ is a matrix, $v$ a vector, and $I$ the identity operator. If we have the equation $w=v+eAv$, it is perfectly fine to write $w=(I+eA)v$, so $v=(1+eA)^{-1}w$. Now the derivative $D$ is a 'matrix' in an infinite-dimensional space, i.e. a linear operator on the space of differentiable functions. So you can work analogously. It takes a lot of effort to make it rigorous (see the arxiv link I posted), but it all works out. \$\endgroup\$ Commented Aug 20 at 2:09
