Part 1: A long slot in a top-side ground plane can act as an antenna, both in terms of radiating and picking up currents that are attempting to flow perpendicular to the slot. You can think of a slot as a "negative wire" of sorts. More detail can be found here.
High-frequency currents that are trying to get from one piece of the top-side ground plane to another (flowing perpendicular to the RF trace) are forced to flow around the borders of the gaps between the pieces. Now consider what happens if the length of the slot equals half the wavelength of the current. The voltage across the slot is forced to zero at the ends of the slot (where the pieces are connected), but this means that the voltage difference across the slot will be highest at the center of the slot. Similarly, the current (across the slot) is forced to zero at the center of the slot, but is maximum at the ends of the slot. This is the electrical "dual" of an ordinary half-wave wire antenna, in which the current is maximum at the center and the voltage is maximum at the ends. The slot and the wire are equally effective as antennas, coupling RF energy to and from the space around themselves.
The multiple vias connecting both sides of the slot to the solid ground plane on the other side "short out" this slot antenna, eliminating that problem.
Part 2: Independent ground planes for certain "noisy" subsystems (or, for that matter, subsystems that need to be particularly "quiet") on a board, which are connected to the system-level ground plane at just one point, serve to confine the return currents for signals inside that subsystem to just that area of the board, preventing them from affecting (or being affected by) other subsystems on the board.
For example, suppose you have a microprocessor-based data acquisition system that has a high-resolution ADC and some analog signal-conditioning circuitry upstream of that. You might create one ground plane for the analog circuitry and another one for the microprocessor and its crystal and other digital peripherals (e.g., a large flash memory chip), and connect each of these to a system ground plane (or to each other) at just one point. This keeps the high-frequency noise of the crystal and the other fast-switching digital I/O signals of the microprocessor out of the ground plane for the sensitive analog circuits. You'll see this if you look at the layouts of evaluation boards that manufacturers produce for their high-resolution ADC and DAC chips.
