A general question:
Lets say I have a square wave signal from 0 to 5 volts. What I would like to do is create a circuit that will convert this 0 to 5-volt signal to a -2.5V to +2.5V for example. ( remove the dc )
I do NOT want to have a negative voltage reference for the -2.5V in my circuit.
What options do you think can create this kind of circuit? (for example, high pass filter maybe with Schmitt trigger? Other options? )
My square wave is at 200kHz and 50% duty cycle.
More info:
The square wave signal drives a transformer and after the transformer, a diode and a capacitor rectify the signal in order to create a DC output.
What I want to build, is a floating voltage that can be controlled by the frequency of my square wave. I need to connect this voltage in another circuit so that is why I use the transformer, for isolation and not having a ground reference on the secondary side.
The above question that I have is more general, in order to understand about level shifting.
In my case:
My AC waveform that I power on the primary side, can be a square wave or sine wave (I am not sure what is the best). The current that I need on the secondary side is about 1A. My transformer is a 1:0.8 (primary:secondary) and the voltage on the secondary side that I need, is about 10-12 volts and this voltage should be adjustable by the frequency or amplitude of the primary side's AC waveform.
Thanks a lot.
