I'm using this TI PTR08100W switching regulatator, and want to use the inhibit pin to keep it turned off except when I am holding down a switch.
According to the datasheet:
The Inhibit pin is an open-collector/drain-negative logic input that is referenced to GND. Applying a low-level ground signal to this input disables the module's output. When the Inhibit control is active, the input current drawn by the regulator is significantly reduced. If the Inhibit pin is left open-circuit, the module will produce an output voltage whenever a valid input source is applied.
And indeed, connecting it to ground turns off the output. But I want it to default to off when the button is not pressed.
Of course, the simplest solution (and the one I use right now) is to use a normally closed pushbutton switch. But that has a couple downsides:
- Normally closed switches aren't as common, so I'm a bit limited in my selection of switches. I've yet to find tiny tactile buttons that come in normally closed, for example.
- Most switches when they wear out tend to fail open, which would turn the power on, and I want the device to fail safely with power being turned off.
So how can I have it default to inhibited, and turn on when pressing a normally open switch?
