I came across the following self-study problem, taken from The Analysis and Design of Linear Circuits (8th edition).
I was not intending to solve the problem, since I am just looking over all problems in the book. Something caught my attention, however. I was looking at node c, the one labeled with \$v_c\$ in the Figure. If I were to apply Kirchhoff's Current Law to then perform node-voltage analysis, I would not know what currents to write down. I know the current flowing into the positive input of the second OpAmp is zero, so that means there is either current going into/coming out of the output of the first OpAmp, and current through the 150K resistor; or else, no current goes through the 150K or out of/into the first OpAmp output. Then, what is the point of cascading two OpAmps?
