I have three heating elements (12, 40W) that I want to connect to a single power source (12V, 16A). If I attach one of the heating elements directly, it draws 2,3A @ 12V. But If I attach 3 heating elements in parallel, they draw only 4,3A @ 12V. Can you tell my why its not 2,3A x 3 = 6,9A and how I could achieve that? I am using these heaters. Thanks for your help, appreciate any hint.
    \$\begingroup\$ Have you measured their resistance separately? \$\endgroup\$
    – PDuarte
    Commented Oct 18, 2018 at 20:12
    \$\begingroup\$ Do all three heat up to the same temperature? Did you measure after they warmed up or when they were still cold? Try putting the heaters on ice to make sure they are all on. One of them probably reached its threshold temperature and turned off. \$\endgroup\$ Commented Oct 18, 2018 at 20:16
    \$\begingroup\$ Did you measure the voltage with all three heaters connected? From your numbers, you shouldn't be overloading the power source - but it is always good practice to check that the voltage is really what you expect. \$\endgroup\$ Commented Oct 18, 2018 at 20:23
  • \$\begingroup\$ Yes, the resistance is the same for each heating element (about 5 ohm) \$\endgroup\$
    – Tom
    Commented Oct 18, 2018 at 20:37
  • \$\begingroup\$ I measured them at room temperature and all three of them get hot although one seems to gets hotter faster than the others. Yes I have measured the voltage with all three connected as well as each one separate. One more thing I noticed is that the current being drawn is slowly decreasing \$\endgroup\$
    – Tom
    Commented Oct 18, 2018 at 20:42
Ok guys I figured it out! Turned out the wires I have been using were just not ment to deliver that much current. Using some proper wires solved the problem. Thanks everyone for your help!
