I'm having a problem with a circuit commanded by a PIR.
I managed to ring a chinese doorbell when someone pass in front of the PIR but the main problem is the two transistors become very hot and I don't understand why. The doorbell is a chinese model like this:
This is the circuit:
When the button is pushed it connect the positive from an LR23A battery to the circuit and send the radio signal to the receiver so I use the PIR and the two transistors to close the circuit when the PIR detect a presence. The battery can provide 55mAh so the circuit has a very low power consumption compared to the TIP122 and TIP127 capacity.
What's wrong with this circuit?
Thanks in advance for your attention.
