9
In order to repair a programmable timer plug, I'm doing some "reverse engineering" on it, it's not for the cost (about $5) but more for learning and recycle thought.
UpDown
I draw the scheme but can't figure out how it is working. With only some resistances and diodes, the 230VAC powered circuit is able to recharge a 1.2VDC small NiMH battery (Dead due to long time unused, replaced by a AA one on the photo), and drive a 48VDC relay. Scheme
What I guess :
  • The varistor VR prevent over-voltage (thunder or electricity company) by making a short circuit witch will making the breaker cut the power.
  • The X2 capacitor is for parasites (And/Or a filter with R2?)
  • The diodes bridge generate the redressed voltage (230 x √2 => 325V)
  • The capacitor C2 delete or reduce the ripple
  • The transistor Q1 provide the relay command (send by the display part)
  • The D2 diode is for fly-back protection (when relay release)
What I'm asking:
  • How are the 48VDC and >1.2VDC voltage generated? Maybe the Zener diode is the key for one of them? But I'm really unfamiliar with this.
  • How is the transistor Q1 activated with D7 diode in other direction?
  • I don't see a real separation between voltages isn't it a safety problem?
For information the programmer still works as before except there are no more "clic" (relay activation) when the programmed hour comes (and of course no power on output) The Q1 base pin voltage change when the programmed hour comes so I guess the display part is OK and didn't opened it.
Thanks for having read (sorry for my poor English level)
[EDIT 27/10/2019]
Before going further with an other equipment repairing, I'm giving a new try to understand and repair this programmable timer plug, first thank you for having helping me till now :)
I do some more analyses and draw the scheme (with fritzing):
Scheme
Where I am with your help :
  • The VR varistor prevent over-voltage (thunder or electricity company) by making a short circuit witch will making the breaker cut the power.
  • The X2 safety capacitor is providing a "capacitive dropper" or "capacitive power supply". The impedance = 1/(2 x Pi x f x C) = 1/(2 x Pi x 50 x 0.33 x 10^-6) = 9.6 Kohm. So the current provided should be Vin/Z = 230/9600 = 24mA
  • The R2 resistor is a bleeding resistor to discharge X2 when the equipment is unplugged.
  • The 4 diodes disposed as a bridge are redressing the voltage
  • The R1 resistor (or "R" on previous drawing) is an additional safety to minimize the maximum current draw.
  • The Z1 Zener diode limit the voltage to 47VDC when the relay is off.
  • The C2 capacitor delete or reduce the ripple of this 47VDC voltage.
  • The Q1 NPN transistor provide the relay command (send by the display part)
  • The R3 and R4 resistor are providing a voltage divider to charge the battery and supply the display part. The voltage = (V x R4 / (R3 + R4))-D1Vdrop = (47 x 2700 / (51000+2700))-1 = 1.36V
  • The D1 diode prevent the battery discharging by supplying the relay when the power is unplugged.
  • The BAT battery provide power to the display part when power is unplugged to maintain the RTC on.
What I do to try to find the problem :
  • I de-soldered the X2 to check it's value, it seems to be still good (about 321nf)
  • I tried to check the voltage on Z1 zener diode, but my multi-meter couldn't find a constant value (I don't have an oscilloscope)
New questions :
  • X2 capacitor set the maximum current, the voltage is set by the Z1 zener diode, the 4 diodes bridge are redressing ? Is this right and how does this all works together?
  • Or is the Zener diode just a security to protect the voltage rising in some failure case? If yes, how is set the voltage?
  • Should the maximum current be (Vin-VZ1)/Z = (230-47)/9600 = 19mA instead of 24mA founded previously?
  • @Sephro Pefhany say "Probably the relay limits the voltage when it is on." How the relay is limiting the voltage?
  • What is the aim of the D8 diode? Protecting the Q1 transistor?
  • What is the aim of the D7 diode?
  • What should I verify next to try to find why the relay isn't clicking anymore? I was planing to check the C2 capacitor although it seems physically OK.
  • What measurement could I do to go further?
Again thanks for having read :) (sorry for my poor English level)
    \$\begingroup\$ Look up the term "capacitive dropper." \$\endgroup\$
    – JRE
    Commented Oct 31, 2018 at 17:03
  • 9
    \$\begingroup\$ +1 for learning and schematic! \$\endgroup\$
    – winny
    Commented Oct 31, 2018 at 17:48
12
X2 drops the voltage--it has impedance \$X_C = \frac{1}{2 \pi f C}\$. R in series limits the peak current. R2 in parallel bleeds the voltage off the capacitor so you don't get a jolt if you touch the pins after it is unplugged.
The zener limits it to the 48V or thereabouts when the relay is off. Probably the relay limits the voltage when it is on.
The 1.4V battery may be a button cell that is a primary cell (not rechargeable) just to power the timekeeping chip. If not it could be trickle charged through a resistor.
Your transistor is swapped E-C (now fixed in the edited version).
The chip does not drive the transistor, that would take power from the battery. Instead it sinks current out of the base to keep the transistor "off", so the power is drawn from the mains.
The lack of isolation is not critical because every part of the circuit that could come into contact with the user is insulated to a high standard (or should be if it's approved). For example, you probably have to remove the power in order to access the battery. Please do not compromise that protection with your experiments, contacting the battery connections with mains attached, for example, could result in a potentially fatal shock.
  • \$\begingroup\$ Good answer, except I don't see why the transistor is swapped ? The collector is connected to the relay, and the emitter to the "ground" through a diode. \$\endgroup\$ Commented Nov 1, 2018 at 0:02
  • \$\begingroup\$ @Charles The symbol orientation looks right, but if that's a 2N5551 NPN, I think Spehro is pointing out that the emitter should be labeled pin 3. \$\endgroup\$
    – penguin359
    Commented Nov 1, 2018 at 0:07
  • \$\begingroup\$ X2 and also R on the opposite side of the diode bridge will both help to drop the 230 VAC mains. I expect most of it will be on X2 so it's not wasted as heat. R is probably an additional safety to minimize the maximum current draw. \$\endgroup\$
    – penguin359
    Commented Nov 1, 2018 at 0:11
  • \$\begingroup\$ @CharlesJOUBERT He edited the drawing to correct the transistor. \$\endgroup\$ Commented Nov 1, 2018 at 8:53
The output to the display is actually triggered from the clock circuit and diode D7 should be in reverse direction.
  • \$\begingroup\$ Hi, I checked multiple times, the D7 diode is placed this way. When tested by multimeter in diode mode it gives 732 from anode + to cathode - and infinity from cathode - to anode +. \$\endgroup\$
    – ROUGEXIII
    Commented Mar 28, 2022 at 20:36
