Can someone help me with this push button?
I want to connect to an Arduino, it works fine with a small one but with this big one it conducts when press and releasing.
The problem is that the push button conducts when pushed and released so 1 push = 2 times conducting. So the Arduino is receiving two signals and turns on and off. I used a debounceing hardware circuit.
small one
andbig one
? ............... the comment about the 2 times conducting makes no sense ............. are you sure that the pushbutton does not latch? (press once to switch on, press again to switch off) \$\endgroup\$
