I have this code and I am having a problem in the product output, any ideas? I've tried a lot and it doesn't work.
This is the full code:
// 32X32 Multiplier arithmetic unit template
module mult32x32_arith (
output reg [63:0] product, // Miltiplication product
// Multiplier controls
input wire [31:0] a, // Input a
input wire [31:0] b, // Input b
input wire [1:0] a_sel, // Select one byte from A
input wire b_sel, // Select one 2-byte word from B
input wire [5:0] shift_val, // Shift value of 8-bit mult product
input wire upd_prod, // Update the product register
input wire clr_prod, // Clear the product register
input wire clk, // Clock
input wire rst // Reset
// Put your code here
// Used registers
reg [63:0] mult_prod;
reg [63:0] mult_prod_temp;
initial begin
product = 0;
mult_prod = 0;
mult_prod_temp = 0;
end
// mux outputs
reg [7:0] z1;
reg [15:0] z2;
reg [63:0] val;
// updating selector inputs
always @(a_sel or b_sel)
begin: test
case (a_sel)
2'b00:
if(b_sel == 1'b0) begin
assign z1 = a[7:0];
assign z2 = b[15:0];
end
else begin
assign z1 = a[7:0];
assign z2 = b[31:15];
end
2'b01:
assign z1 = a[15:8];
end
else begin
end
2'b10:
assign z1 = a[23:16];
end
else begin
end
2'b11:
assign z1 = a[31:24];
end
else begin
end
endcase
end
always @(z1 or z2 or shift_val)
begin: Arithmetics
// 8x16 multiplier
mult_prod_temp = z2*z1;
// Shifter
mult_prod = (mult_prod_temp << shift_val);
// Output
val = (product + mult_prod);
product <= val;
end
// End of your code
endmodule
I'm trying to implement a 32x32 multiplier using 8x16 multiplier, but I am having a problem in the output (product), it does not give me the right expected answer (check the attached photo below), and I'm trying to figure out where's the problem, whether it's in the syntax of the always procedure or somewhere else.
Thanks in advance!
