The following CE Amplifier Small-Signal Equivalent Circuit and nodal equations are from this site.
I'm completely lost how they form the above KCL Equations for the nodes B, C and D.
For example, for B node the currents \$\frac{v_i}{R_s}\$ and \$\frac{v_e}{r_{\pi}}\$ does not make sense to me for a KCL equation at node B. \$\frac{v_i}{R_s}\$ is a current when \$V_i\$ and \$R_s\$ is shorted. What is that to do with the KCL?
Similarly for node C what is the current \$\frac{v_e}{r_o}\$? Again this equation doesn't make sense to form a KCL for node C.
What are the current directions in these cases? And in this model \$R_C\$ is shorted but why \$V_i\$ is not shorted to ground?(as done in a any small signal analysis) Can someone explain how these equations form a bit in more detail?
