I am looking at the datasheet for the MCP4725 DAC and trying to find the minimum voltage the DAC will output. In other words, when my code tells the DAC to output 0v, what will the output be? There are two parameters listed in the datasheet that I think are related to what I am looking for. One is the Offset Error of the DAC, and the other is the Output Low Voltage. Anyone know which one is the parameter that tells me the minimum DAC output?
Here is the MCP4725's datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/22039d.pdf
