I have solar hybrid inverter at home that's connected to the mains using both, the line and neutral wires. However, to save the costs, I've connected the load to it using a common neutral i.e. I've daisy chained (or looped) the neutral input to the neutral output behind the inverter.
This works perfectly, but an electrician tells me that electrical meters (from the utility company) still measure the current when using the neutral as common, and this is the first time I'm hearing this.
Few points to note are:
- My electricity from the utility company is single phase.
- The inverter powers critical load in the house during the day using solar energy, while non-critical load is powered over utility.
- Both critical and non-critical loads share the same neutral line.
Can someone please explain how current measurement in this scenario would work? Should I be running a separate neutral wire from the inverter to my critical load?
Update: Below is a diagram to better explain the above:
