My original file has the following
module circuit_320a(A,B,C,D,N,F);
    output N,F;
    input A,B,C,D;
    wire w1,w2,w3,w4;
    and #(30) G1(w1,C,D);
    or #(30) G2(w2,w1,B);
    and #(30) G3(w3,w2,A);
    not #(30) G5(N,c);
    and #(30) G4(w4,B,N);
    or #(30)(F,w3,w4);
endmodule
and my testbench has these
`include "ask.v"
module t_circuit_320a_delay;
    wire N,F;
    reg A,B,C,D;
t_circuit_320a_delay M1 (A,B,C,D,N,F);
initial
  begin
     A=1'b0; B=1'b1; C=1'b0; D=1'b1;
  end
  initial #200 $finish;
   $dumpfile("ask.vcd");
   $dumpvars(0, ask_tb);
endmodule
When I try to compile I get syntax errors, why is that?
I have named the original file ask.v and the testbench ask_tb.v
Errors
  • \$\begingroup\$ Please share the complete error messages. It will make it much easier to find the problem. \$\endgroup\$
    – The Photon
    Commented Mar 30, 2019 at 21:54
  • \$\begingroup\$ One thing, you didn't name your last or gate like you did the other gates. \$\endgroup\$
    – The Photon
    Commented Mar 30, 2019 at 21:56
  • \$\begingroup\$ @ThePhoton yes one moment please , see edits \$\endgroup\$
    – user170589
  • \$\begingroup\$ @ThePhoton Yes because it is the output of the schematic \$\endgroup\$
    – user170589
    Commented Mar 30, 2019 at 21:58
You need to read the FAQ.
Specifically, the $ commands need to be in an initial block, to wit:
`include "ask.v"
    wire N,F;
    reg A,B,C,D;
  circuit_320a M1 (A,B,C,D,N,F);
  initial begin
  end
  initial begin
    $dumpvars(0, t_circuit_320a_delay);
  end
endmodule
It will also help if you instantiate the correct module. t_circuit_320a_delay should be instatiating circuit_320a, not itself, and the $dumpvar call needs to refer to t_circuit_320a_delay, not the name of the file.
  • \$\begingroup\$ I still get errors , please see the edit \$\endgroup\$
    – user170589
    Commented Mar 30, 2019 at 23:03
  • \$\begingroup\$ Neverimind I had a syntax error , wrote inital instead of initial \$\endgroup\$
    – user170589
    Commented Mar 30, 2019 at 23:08
