I'm working working with NEXYS4DDR board which has two 4-digit 7 segment displays. Using the proper binary-bcd converter I can display numbers, the problem is... the same number is displayed in all the displays (assuming all are activated), like: 1 1 1 1 1 1 1 1 because I can only control one set of segments (CA, CB, CD, CE, CF, CG) and not one set of segments for each display. How can I separate them? To show, like 1 2 3 4? A SystemVerilog or Verilog solution would be preferred since that's the HDL I'm currently learning.
For reference, the board is: https://reference.digilentinc.com/reference/programmable-logic/nexys-4-ddr/start
