5
I am trying to program the MSP430 (on an MSP-EXP430F5438 evaluation board) under Linux using gcc-msp430 (I eventually will do code larger than the 16k that the free version of the Code Composer allows).
As a debugger, it is recommended to use mspdebug, but when I try to use it, it doesn't connect to the FET430UIF.
~$ sudo mspdebug uif
MSPDebug version 0.19 - debugging tool for MSP430 MCUs
Copyright (C) 2009-2012 Daniel Beer <[email protected]>
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
TI3410 device is in boot config, setting active
Initializing FET...
FET protocol version is 20408002
Configured for Spy-Bi-Wire
ti3410: usb_bulk_read: No error
warning: fet: set VCC failed
ti3410: can't send data: No such device
fet: command C_IDENT1 failed
fet: identify failed
Trying again...
Initializing FET...
fet: open failed
ti3410: warning: TI_CLOSE_PORT failed: No such device
The same device works correctly with Code Composer running on a Windows virtual machine or on a physical Windows system, so I know it is working.
I tried on Ubuntu 12.04 and on Arch Linux and got the same errors.
As recommended in an answer, I tried with -d and got further, but didn't work:
~$ sudo mspdebug uif -d /dev/ttyUSB0
[sudo] password for renan:
Trying to open UIF on /dev/ttyUSB0...
Initializing FET...
Set Vcc: 3000 mV
Device ID: 0x0580
Device: MSP430F5438A
Code memory starts at 0x5c00
Number of breakpoints: 8
uif: read error: Connection timed out
fet: warning: message C_IDENT3 failed
fet: message C_IDENT2 failed
Trying again...
Initializing FET...
fet: open failed
What is wrong?
  • \$\begingroup\$ I think this is the most suitable SE for this question, but I'm not sure, feel free to migrate it anywhere else if suitable. \$\endgroup\$
    – Renan
    Commented Oct 10, 2012 at 14:14
This mail thread suggests that you need to specify the -d option like this:
They state that this is necessary for FET firmware 2.04.09.001 but not necessary for 2.04.05.003.
Your firmware is version 2.04.08.002. So this issue may affect you or it may not.
  • \$\begingroup\$ It gets slightly farther, but still doesn't work. I added the output to my question \$\endgroup\$
    – Renan
    Commented Oct 10, 2012 at 17:46
    \$\begingroup\$ @Renan Are you connecting through JTAG? If so you need the -j option as well. Otherwise try upgrading to the latest release of mspdebug. There are some changes to MSP430.DLL (a.k.a tilib) but I'm not sure what version they were rolled into. \$\endgroup\$ Commented Oct 11, 2012 at 14:02
  • \$\begingroup\$ I tried with -j, and did not work too. Will try upgrading \$\endgroup\$
    – Renan
    Commented Oct 11, 2012 at 16:07
  • \$\begingroup\$ Well, eventually it started working. (Don't know why). Marking this as the answer, since I needed -d and -j parameters. \$\endgroup\$
    – Renan
    Commented Oct 29, 2012 at 2:23
