I have a question concerning this op-amp problem for which I need to find an expression for \$v_{out}(t)\$, where \$V_B\$ has a constant value:
So far, I've found that we can describe \$v_{out}(t)\$ by the following equation :
$$v_{out}(t) = R_2 \times I_{R_2} $$
And I know that :
$$V^{-} = V^{+}$$.
Now, I have some problems to use \$R_1\$ in the analysis, since I know that the current passing through it is \$0 A \$.
Therefore, I tried to use another equation with the gain of the op-amp :
$$V_{out} = A \left( V_{in} - V_B \right)$$
But I don't think I can find an expression. Therefore, I wanted to know if it's possible to find an expression without using this last equation ?
Edit : Added the original problem. The text is the following :
Pour ce circuit VB est constante. Déterminer vout(t) en fonction de
vin(t) et des autres paramètres. Calculer sa transformée de Laplace
en fonction de Vin(s).
