I am trying to set the current limit on a NEMA 17 stepper motor. I found a tutorial but it's asking about the current rating. From my stepper motor datasheet, the only information related to current is the following: Rated Current (Amps/Phase) = 1.68 A. In the online tutorial that i'm following, this is the example given for their stepper motor: NEMA 17 200steps/rev, 12V 350mA. So, i'm quite sure that the current rating that is being asked is not 1.68 A. Maybe i need to calculate the current rating??
Edit: Here are the more complete specs for my hybrid stepper motor, model: MT-1703HS168A
Rated Current (Amps/Phase): 1.68
Holding Torque (kg.cm): 4.4
Resistance (Ohms/Phase): 1.65
Inductance (mH/Phase): 3.6
Inertia (g.cm2): 54
Detent Torque (g.cm): 150
Weight (kg): 0.28
Recommended voltage: 12 - 24 V
