So I have created the attached Wien bridge oscillator using a transistor differential amplifier, the Negative gain is controlled using a potentiometer, center tapped and yes I understand that in the real world I would need to use an AGC to stabilise the output.
My problem is that the calculated frquency given the component should be,
f = 1/2picr = 1 / 2*3.141*10nF*5koHM = +-318.369Hz, But as you can see on the image, I'm getting something in the tune of +-863.04,
I have searched everywhere and I don't know what i'm doing wrong here,
