I have googled this quite profusely, and can't seem to find a straight answer. I am a consummate newb when it comes to electronics, so please forgive my ignorance.
I am wondering how it is possible to send approx. 5V* to more than one logic gate simultaneously from the single output (1-bit) of a previous gate and/or dip-switch, assuming one was to build the system physically on a breadboard.
I have just figured out in my head and on paper how to make a very basic adder work, with the help of this site.
The problem, if I'm remembering my high school science teacher correctly, is:
The only way to "double-up" a voltage to 10V (to supply 2 gates with 5V "1" each) would be to run the original 5V signal in parallel, rather than splicing/forking (which, I believe, would be in series, not parallel), which would halve it to ~2.5V (not sure on that, just my memory of how electronic systems were explained back then).
For the adder, you have to send the "A-bit #1" to two different gates from a single dip-switch. Can someone please explain (physically and in terms of voltage) how this is possible. This is not for homework, simply for my own edification/hobby. Thanks in advance for your answers.
If necessary, I can upload my diagrams (on paper).
*Assuming 5V is the "standard" HIGH voltage i.e. "1" for this type of system, as per the article, and that ~0V is LOW voltage, i.e. "0".
