In Eagle CAD, in a 4 layers board (signal-ground-power-signal) how do I avoid that a through hole via from, for example, the top signal layer to the power layer is electrically connected to the layer in between (ground)?
Do I need to manually move the ground polygon or overlay a "cutout" polygon or can it be done automatically? Can Eagle CAD place a cutout or a no-copper space around the Via on the in-between layer?
Thanks
