I need help on choosing type of regulator base below design requirements
Design Spec:
Input Voltage = 12V
Output Voltage = 5V
max Current = 3A
Power (12-5)*3 = 21W
EX: Without heat sink 60C/W (lm1084 ) So: 21W*60C/w = 1260C which is out of questions
So what is best option regulator with budget of under $3 (for Qty 1) and must be surface mount
Main concern is the heat generated by the regulator
    \$\begingroup\$ What is, in your opinion, the difference between a Switching Regulator and a DC to DC converter?. Why would you rather not use a DC to DC converter? \$\endgroup\$
    – MartinF
    Commented Aug 1, 2019 at 18:56
  • \$\begingroup\$ Thanks for information link, I can use DC to DC converter but I could not find any in digikey which meet the space and budget. \$\endgroup\$
    – Shahreza
    Commented Aug 1, 2019 at 19:33
  • \$\begingroup\$ @Shahreza You'll have to build one with ICs I guess. \$\endgroup\$
    – DKNguyen
    Commented Aug 1, 2019 at 19:36
  • \$\begingroup\$ Sorry I will go head and add the budget and space as design requirement, All I need to know what type of regulator is good for this job \$\endgroup\$
    – Shahreza
    Commented Aug 1, 2019 at 19:48
  • \$\begingroup\$ Best solution for under $3 is just buy a 5 V wall wart, and ignore the 12 V you have now. \$\endgroup\$
    – The Photon
    Commented Aug 1, 2019 at 20:03
How to select your DC-DC... To go from 12V to 5V you need a buck converter, so let's check that in the search engine. Now, for the other criteria...
  • Ready made or DIY?
That's the first question to ask, especially if you're not familiar with designing DC-DC converters. There are a lot of small board-mount modules available, for example this one. Search for "PoL (point of load) DC-DC" or "board mount" etc. You'll need a non-isolated buck. A ready-made module can be a very good idea for a small production run when you don't want to waste time on designing a DC-DC.
  • Synchronous or asynchronous rectification?
From 12V to 5V, duty cycle will be 5/12 = 0.42 thus a converter with asynchronous rectification will have a diode conducting 42% of the time, wasting 3A * about 0.5V * 0.42 = 0.625 Watts. A synchronous rectification converter will be a bit more efficient, it might waste about 0.3W instead in the bottom FET (wet finger in the wind calculation with 40 mOhms FET and switching losses equal to conduction losses). Since the difference between synchronous and asynchronous is less than 1.5% efficiency in your case, if asynchronous is cheaper, no problem, just use that. Synchronous becomes very useful at very low output voltages like 1.2V though.
  • Internal switch vs external?
An external FET means you can pick any FET you want, but it is an extra part and extra cost. However, an IC with an internal MOSFET will cost more than an IC without it. If uses synchronous rectification, then it is 2 FETs, or a single package dual FET. So you need to add the price of extra parts if you use a chip without internal FET(s).
  • Frequency
Higher frequency shrinks the inductor and the input/output caps, and reduces core losses. It also increases switching losses.
  • Other features
Like efficiency at low load, losses at very low load or no-load, "power good" output, ENABLE input, input voltage range (do you want it to go down to 5V?), how much noise/ripple you can tolerate, EMI, etc.
Knowing this, just input your requirements into webench and check if it generates designs you like. You can set it to optimize for cost, footprint, or efficiency. Of course, it wants you to buy TI chips, but nothing stops you from using it as inspiration and using another similar chip from another supplier.
The first suggestion is this chip which looks pretty good. Note if your "3A max" load spends lots of time drawing 3A, it may be beneficial to select a chip with peak efficiency at 3A, and that would be a chip capable of a bit more current, perhaps a 4A chip. The 3A chip's efficiency peaks at 1-2A.
  • \$\begingroup\$ Thanks for detail answer. My question is does the buck regulator generate as much heat as linear regulator. Since this is my main problem is the heat since thermal junction of linear regulator is too high \$\endgroup\$
    – Shahreza
    Commented Aug 1, 2019 at 20:39
    \$\begingroup\$ Switching converter will generate much less heat, if it has efficiency of 90%, at output power of 15W it will dissipate about 1.6W instead of 21W for linear regulator. But if you ask this question it means you don't have experience with switching DC-DC converter and you should consider buy a ready-made unit (only costs a few $). Only design one if you want to learn how to do it. \$\endgroup\$
    – bobflux
    Commented Aug 1, 2019 at 20:51
  • \$\begingroup\$ That's exactly what I am trying to do build board for internal use. Thanks for the help \$\endgroup\$
    – Shahreza
    Commented Aug 1, 2019 at 21:04
    \$\begingroup\$ So it is low quantity, right? If you spend several days learning how to implement a DC-DC, it can be more expensive than just buying a ready-made module. If you want to design your own and learn, then sure, it is interesting, and a good goal too... but keep in mind what you want to do: do you want a power supply, or do you want to learn how to design one? \$\endgroup\$
    – bobflux
    Commented Aug 1, 2019 at 22:48
  • \$\begingroup\$ I would like to learn first and then build protype \$\endgroup\$
    – Shahreza
    Commented Aug 2, 2019 at 2:10
