I need a transistor lesson that I could not find on the internet:
I have a standard GND-PNP-Load-(-20Vcc) arrange:
0V-Transistor-Load--20V
(The two resistors attached to the base are to form a divider - ignore the values).
Im struggling because if I leave the base floating (for testing purposes), the transistor conducts.
I tried making every thinkable voltage divider between GND and -20V to feed the base. The voltage on the base never goes above -0.65V, where (I suppose) it would cutoff.
Was it a NPN transistor, leaving a small voltage (<0.6) on the base would cut it off. Not here.
  • It's a BC556.
  • The transistor does work well on the linear region
  • The datasheet says ICBO is -15nA. Very low value. Does this change anything ?
  • Those schematics come from a humble simulator that doesn't allow me to tag the components.
I'm clearly missing a polarity rule or something. Who can point it out ?
Edit:
The schematic above was a simplification. After no success following your suggestions, I started to think that a simplification was not a good idea (probably the "load" messes with the system).
The device on the collector is actually the control pin of the LM7905 IC, which sinks a maximum of 3mA.
I'm away from a PC, so I won't represent it. But you can replace the current source below with it.
Just hope this information doesn't add to the confusion...
My final objective is to vary this current, as best as possible, from 0 to 3mA using the transistor.*
Around -10V is the voltage on this pin when the current is 2.7mA. This voltage probably varies with the current
Non-Simplified Circuit
*Must be a transistor. A resistive divider doesn't span the minimum and maximum current. Also, a transistor worked very well on the positive side.
  • 4
    \$\begingroup\$ What is the purpose of the 1 kohm resistor between base and -20 V? (Please add designators to your schematic so we can say things like "R2" instead of "the 1 kohm resistor between base and -20 V") \$\endgroup\$
    – The Photon
    Aug 2, 2019 at 17:58
  • 7
    \$\begingroup\$ If you connect the base directly to the emitter it should not conduct. If it does, it is broken. By the way: leaving the base floating will give erratic behavior. Just don't. \$\endgroup\$
    – Oldfart
    Aug 2, 2019 at 17:59
  • 5
    \$\begingroup\$ Double-check the pinout. Transistor manufacturers will use all possible combinations of leadouts, even though the usual one is very common. \$\endgroup\$
    – TimWescott
    Aug 2, 2019 at 18:06
    \$\begingroup\$ A BJT isn’t a voltage comparator. It just suddenly doesn’t start conducting at a specific base emitter voltage. It’s a non linear but gradual thing hence it is usable as a signal amplifier. \$\endgroup\$
    Aug 2, 2019 at 18:23
    \$\begingroup\$ I'm also not sure why you have a current source as a load. If you're simply trying to convince yourself you can modulate the colector current with the base polarization you should simply have a resistor as a load as you had initially. \$\endgroup\$
    – joribama
    Aug 3, 2019 at 3:56
Browse other questions tagged or ask your own question.
