I two sinewave signals with same frequency. I want to measure phase shift between two signals. There will be a small phase difference between two signals. I am using ATmega32-A micro controller and external ADC AD7798 to read the voltage of both signal. I am able to read both signal voltages using SPI communication. How to find Phase difference between two sine signals. I am using CodeVisionAVR compiler.
I know that phase shift between two signals can be find out using the fallowing formula.
A(t)= Am sin(Wt+/-theta).
I know only amplitude(Am) and w =2*pi*f. But How to calculate phase difference between two sinewave signals with knowing amplitude and frequency. Any suggestions please.
I have implemented timer functionality to get zero crossing points using the fallowing code.
void main(void){
init(); //Initialize controller
debug = 0; //Controls output during motor running
while (1){
if(rx_counter0) getCom();
if(Command) runCom();
if(logInt > 0){
if(now){
if(!(unixTime % logInt)){
if(flag){
flag = 0;
now = 0;
#asm("WDR"); //Reset WD timer
} // EOF "while(1)"
} // EOF "main(void)"
void init(void){
#asm("cli"); //Disable global interrupt
// Input/Output Ports initialization
// Port B initialization
DDRB=0xBF;
// Port C initialization
DDRC=0xC3;
// Port D initialization
DDRD=0xFC;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: On
// USART Transmitter: On
// USART0 Mode: Asynchronous
// USART Baud Rate: 9600
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x67;
UCSRA=0x00;
UCSRB=0xD8;
//UCSRC=0x86;
// ADC initialization
// ADC Clock frequency: 1000 kHz
// ADC Voltage Reference: AREF pin
// ADC Auto Trigger Source: None
// Digital input buffers on ADC0: On, ADC1: On, ADC2: On, ADC3: On
// ADC4: On, ADC5: On
//DIDR0=0x00;
ADMUX=ADC_VREF_TYPE & 0xff;
ADCSRA=0x84;
//Global enable interrupts
#asm("sei")
unsigned int timer_phase (void)
ResetTimer1(); //reset timer to zero
while(selcase(1) > 0)
//do nothing until input channel crosses zero
StartTimer1(); //start timer counting
while(selcase(5) > 0)
//do nothing until output channel crosses zero
StopTimer1(); //stop timer counting
time_delay_ticks = get_timer_ticks(); //get the number of timer ticks between zero crossings
time_delay = ticks_to_time(time_delay_ticks); //need to get timer ticks into time domain
period = 1 / WaveFreq; //get the period from the known frequency
phase_delay = (time_delay_ticks / period) * 360; //calculate phase delay */
return phase_delay;
interrupt [TIM1_COMPA] void timer1_compa_isr(void){
unixTime++;
now = 1;
void StartTimer1(void)
TCNT1H = 0x00;
TCNT1L = 0x00; //Start counting from 0
OCR1AH = 0x0E;
OCR1AL = 0x0E; //Timer 1 reload value OCR1A = fCLK/(fOC1A*2*n)-1 REMEMBER 2 * OCR1A!
TIMSK = 0x02; //Enable timer 1 output compare A interrupt
TCCR1A = 0x00;
TCCR1B = 0x0D; //Start timer 1 in CTC-mode (4) with prescale 1024
void StopTimer1(void)
TCCR1A = 0x00;
TCCR1B = 0x00; //Stop timer 1
TIMSK = 0x00; //Switch of interrupt
void ResetTimer1(void)
TCCR1A = 0x00;
TCNT1H = 0x00;
TCNT1L = 0x00;
unsigned int get_timer_ticks(void)
unsigned int i;
i= TCNT1H;
i= i|TCNT1L;
return i;
when i run this code I am not getting any errors, But I am not able to enter any command from hyper terminal. When comment this whole function then only i am able to get output and i am able to enter commands from hyper terminal. Help me if any thing with timer function start and stop and reset and get_delay_tricks. Or any thing wrong with interrupts.
