This is a board from a Johnny Lightning V-bot, it has these SMD 6 pin components that just have a M03 and a dot on one of the terminals. Does anyone have a datasheet or any idea on how to ask for one to replace it? It helps with switching direction on a motor that transforms the upper half, and it's right on top of the hip motor connector.
This is the component, roughly 2.9 mm by 1.5 mm:
Picture 1
This is where it goes:
Picture 2
It's most likely an ROHM QS6M3 dual N+P channel MOSFET.
  • \$\begingroup\$ thanks! gonna search those!!! \$\endgroup\$ Commented Aug 29, 2019 at 4:42
  • \$\begingroup\$ You're welcome. The datasheet I linked is on Mouser's website so that might be a hint as to a source. \$\endgroup\$ Commented Aug 29, 2019 at 4:43
