The always
block works only if there's something to "trigger" it. In your example, there were no variables on the RHS of any statements, so @*
effectively reduces to null.
Of course, initial
would have worked just fine ... or always begin
(without the @*
And don't forget that you don't need to use begin/end
with always
or initial
— if you have only a single statement, it's perfectly valid to write
reg b;
initial b <= 1;
or
always @(posedge clock) data_pipe <= data_in;
From your comment:
I am just trying to learn the difference between reg and wire types in Verilog. I learnt that 'reg' can be used to design combinational circuits like gates. So I think it does not always mean a register. It can be wires too in hardware.
No, reg
does NOT mean "register". It's a very confusing part of Verilog syntax.
Basically, reg
variables can be assigned to in process blocks (initial
or always
statements), while wire
variables are assigned to outside such blocks (assign
statements, module port connections, etc.)
