For a 2-wire transmission line (antenna lead-in wires, but also a DC flashlight, or a 60Hz lamp-cord,) the fields in 3-dimensions look more like this below, where the red lines are the magnetic field, and the gray lines are the e-field.
Above, the field-pattern for only two planes is depicted, while in reality, there is a stack of infinitely many such planes. Refer to your textbook diagram, and you'll see that yours is a simplified "side view" of the fully 3D version. We treat the two wires as capacitor-plates having opposite charge. Also, we treat the two wires as part of a 1-turn electromagnet (a long, rectangle-shaped loop.) Multiplying the fields together as vector cross-product gives the power-density at any point in space ...or multiplying voltage by amp-turns (for 1-turn loop) gives the total energy flow: watts.
For a disconnected pair of wires, there would be zero current, but significant voltage and e-field, with no energy-flow. That's the electrostatic case for circuits: voltage without current.
Or, for a superconductor rectangle loop, there would be zero voltage, but significant current and b-field, with no energy flow. That's the magnetostatic case. Next, add a resistor-load to the loop, and also insert an energy-source, and then we have both voltage and current together (the cross-product of e-field with b-field,) which produces a one-way energy-flux from the power supply and into the resistor. Like this below:
- E-cross-B, the energy-flux or "Poynting field" in 3D
Notice that there is no lower limit to the frequency. The description applies both to the GHz 2-wire lines, as well as battery-powered DC circuits. (Most textbooks miss this important point. Transmission-line theory applies to flashlights and washing machines! Kraus "Electromagnetics" is one book which gets it right.) Even at DC, with waves of "infinite wavelength," the energy-flow is still parallel to the wires, while the e-field and b-field vectors are everywhere at 90deg. (Or, imagine 60Hz waves many thousands of miles long. In the center of each "lump" of traveling 60Hz radiation, the fields are perpendicular, and the energy is flowing parallel to the two wires.) It's not the EM waves which are transverse, it's the very field-vectors themselves which are transverse, even at DC with no waves apparent. Electric circuits are both inductors and capacitors at once, and that's why EM energy can propagate across them.
An electric circuit with a source and a load, and with an energy-flow propagating between the two ...it's a unique electronic component: a kind of "coil-pacitor!"
