I'm given these ratings /spec for load cell / sensor:
- Range: 0-200kg
- Output sensitivity: 0.7 ± 0.15mV / V
- Nonlinear: 0.05% F.S
- Hysteresis: 0.05% F.S
- Repeatability: 0.05% F.S
- Creep: 0.05% F.S/3min
- Zero output: ±0.1mV/V
- Input impedance: 1050±10Ω/1050±10Ω (self-compensation) Output impedance: 1050 ± 10Ω
- Operating temperature: -10~+45°C
- Wiring method: red (power positive), black (power negative), green (signal positive), white (signal negative)
- Zero temperature drift: 0.05% F.S/10°C
- Temperature sensitivity drift: 0.05% F.S/10°C
- Insulation resistance: ≥2000MΩ
- Excitation voltage: 3~10VDC
- Overload capability: 150% F.S
- Four-corner error: ±0.05% F.S
I know this is likely dumb question, but is the sensitivity there 0.7V +/- 0.15mV, or is this 0.7mV +/- ..? Probably 700mV/V is too much, but 0.7mV/V sounds too little .. ? (or does it..)
If 0.7mV/V, if I'm applying 5V input - that's my plan - this will be output range 0 - 3.5mV, which seems too low ?
