I'm wondering if I can use an X or Y rated film cap for high frequency DC link filtering/snubbering. The system will be a rectifier+inverter, so the cap in question will go on the DC link between the rectifier and inverter. There will be a big bulk cap (>3mF) to deal with low frequency ripple. The job of the X or Y cap is to do localized filtering for higher frequency noise.
The reason I want to use an X or Y cap in the DC link is that the X & Y caps typically have UL approval while caps listed as DC link specific rarely have UL approval. To achieve UL approval on our product we will likely need UL approval on our DC link caps. Assuming the X or Y cap meets all the voltage and current ripple requirements, is there anything else to consider when using an X or Y cap in the DC link?
