I have this code to blink an array (8-led) of led one after one:
#include <avr/io.h>
#include <avr/delay.h>
#define dela 500
int main (void)
    DDRC = 0xFF;
    for(int i=0; ; i++,i%=8)
        PORTC |=(1<<i);
        delay_ms(dela);
        PORTC &= ~(1 << i);
        delay_ms(dela);
I want to light up those led partially, like dimmed version of this, something like PWM
Now my question is how can I do that, how can I write analog output ?
Micro-controller : ATmega8A - PDIP
    \$\begingroup\$ you would require a DAC for analog output ... that is different from PWM ... an analog output is not necessary for varying the brightness of an LED ... a PWM signal is preferrable because it does not involve analog voltage levels \$\endgroup\$
    – jsotola
    Commented Sep 28, 2019 at 21:18
  • \$\begingroup\$ Have you considered using larger resistors? You only need one resistor since there will only be one running at a time. \$\endgroup\$ Commented Sep 28, 2019 at 21:20
    \$\begingroup\$ If you want to minimize software overhead, I would recommend getting a 3-to-8 decoder like the 74HC138 and connecting the PWM out to one of the enable lines. This would require only four pins and greatly reduce software overhead. \$\endgroup\$ Commented Sep 28, 2019 at 21:32
  • \$\begingroup\$ PWM is solved , I just need how can I write analogWrite() like thing in avr as in arduino \$\endgroup\$ Commented Sep 30, 2019 at 17:19
Modulate the LED "on" time.
Something like this.
    for(int k=0; k<26; k++)
        PORTC |=(1<<i);
        delay_ms(10);
        PORTC &= ~(1 << i);
        delay_ms(10);
    delay_ms(dela);
  • \$\begingroup\$ I couldn't find any usage of k, What i want is like instead of output true of false, setting or resetting,0 volt or 5 volt. I want to write an analog output. \$\endgroup\$ Commented Sep 28, 2019 at 16:39
  • \$\begingroup\$ what does this mean? ... I couldn't find any usage of k \$\endgroup\$
    – jsotola
    Commented Sep 28, 2019 at 19:01
  • \$\begingroup\$ You are using k in the loop and iterating 25 times. And then using the old code, no usage of k. So will it actually dim the light? I haven't tested yet. \$\endgroup\$ Commented Sep 29, 2019 at 11:41
  • \$\begingroup\$ Now I have got it after testing it.. Can you edit the answer and help me with the analogWrite() type thing \$\endgroup\$ Commented Sep 30, 2019 at 17:17
  • \$\begingroup\$ that is a different question ... post another question \$\endgroup\$
    – jsotola
    Commented Sep 30, 2019 at 23:07
