I'm trying to implement a rather complex (at least for me!) system on a Cortex M4 mcu: LPC4370. This one has HighSpeed ADC (up to 80Msps), DMA and DSP (Single Instruction Multiple Data) instructions. Here's what I want to do:
- Let the ADC sample in a continuous manner (at least at 10 Msps)
- Move the data to SRAM
- Process them in real-time w/ cortex M4 DSP (pulse shaping filtering)
MCU clock is 204 MHz and for now let's assume ADC fs is not a design spec, but ideally I would like it to be as high as it can. So I need the code to be as fast as I can. Here's the MCU memory set up.
And here the AHB MULTILAYER MATRIX
As of now I am considering more the general firmware architecture, and specifically memory management. Some considerations:
- I don't want core M4 and DMA to fight for memory: I need the DMA to be able to write data while the M4 is doing the processing
- most of the code and all acquired data should be in SRAM for faster execution
- Instruction fetch should not interfere with data storing (DMA) and processing (M4)
In the LPC4370 user guide (chap.2):
To optimize the CPU performance, the ARM Cortex-M4 has three buses for Instruction (code) (I) access, Data (D) access, and System (S) access. The I- and D-bus access memory space is located below 0x2000 0000, the S-bus accesses the memory space staring from 0x2000 0000. When instructions and data are kept in separate memories, then code and data accesses can be done in parallel in one cycle. When code and data are kept in the same memory, then instructions that load or store data may take two cycles.
My idea at the moment is to hold the sampled data in two different buffers placed in two different memory areas (like LocRam128 and LocRam72) and "ping pong" DMA and M4 between these two areas. Only problem is that these are the two areas used for instruction (I). So I guest code should be placed here also, and this is not good to me. I wonder how could I use RAMAHB32 effectively since it is only connected to M4 system bus (S) and not to data (D) nor instructions (I).
Any hints?
